I would like to share a Fritzing part for the common blue SCD41 CO2 sensor breakout with a 4-pin I2C header. I made it for an ESP32-C6 sensor shield and want to share it with everyone.
Please note: this is a community part, not an official Sensirion part. It is based on the SCD40 part by Viktar Karpach (vkarpach in forums) - thank you! It also includes the fixes Peter (vanepp) suggested in his review of that part: https://forum.fritzing.org/t/scd40-co2-sensor/21496/2
Download: SCD41_CO2_Sensor_4pin.fzpz (4.4 KB) - import it into Fritzing (File > Open, or right-click a parts bin > Import).
**About the part**
- Pins: GND, VDD, SCL, SDA on a 0.1 in header, named like the board labels. I2C address 0x62.
- Breadboard: the whole drawing is in the breadboard layer, so the part shows up in image exports. The pins are exactly 0.1 in apart, so wires line up with every pin. The pin circles are the connectors themselves.
- Schematic: pins 100 mil long on the 100 mil grid, with terminal points at the pin ends, so wires connect to the end of the pin.
- PCB: 4 through-hole pads (0.038 in holes), square pad for pin 1 (GND). The board outline (21.6 x 13.4 mm), the sensor and the mounting hole are in silkscreen, so you can see where the module sits on your board.
- The icon has its own svg file. In Fritzing 0.9.3b, a part whose icon reuses the breadboard svg can get its breadboard image replaced by another part’s when the sketch is saved and reloaded.
- Family “CO2 Sensors”, the same as the SCD40 part.
- The “SCD41” text on the sensor cap is only there to tell it apart from an SCD40 in breadboard view.
- The board size is taken from the SCD40 part. If your board is different, please tell me.
- Tested in Fritzing 0.9.3b: it loads in a sketch, and the breadboard, schematic and PCB views export as images and Gerbers.
License: CC BY-SA 4.0.
Feedback is welcome. If you see something wrong, please tell me and I will fix it.
