SC03-C2H5OH - Electrochemical Ethanol Module
SC03-C2H5OH electrochemical ethanol module is a general-purpose, miniaturized module. Using the electrochemical principle to detect C2H5OH existing in the air has good selectivity and stability. SC03-C2H5OH is a general purpose gas module designed and manufactured by combining mature electrochemical detection technology with sophisticated circuit design. It has digital output and analog voltage output, and is suitable for various application circuit schemes.
Download:
SC03-C2H5OH - Electrochemical Ethanol Module.fzz (15,3,KB)
Manufacturer URL: Sensor De Detecção De Gás 0-500ppm Uart,Sensor De Saída De Álcool Eletroquímico C2h5oh,Sc03-c2h5oh - Buy C2h5oh Alcohol Sensor Module,Electrochemical Ethanol Sensor Module,Figaro Ethanol Gas Sensor Product on Alibaba.com
Your part has a number of problems. FritzingCheckPart.py has this to say about it:
$ FritzingCheckPartw.py ‘part.SC03-C2H5OH - Electrochemical Ethanol Module_e4edef09d1bbeff43f4b735d8d983617_1.fzp’
**** Starting to process file part.SC03-C2H5OH - Electrochemical Ethanol Module_e4edef09d1bbeff43f4b735d8d983617_1.fzp
**** Starting to process file svg.breadboard.SC03-C2H5OH - Electrochemical Ethanol Module_3d6c130f5103ed2c88216d388420ac06_1_breadboard.svg.bak
**** Starting to process file svg.schematic.SC03-C2H5OH - Electrochemical Ethanol Module_3d6c130f5103ed2c88216d388420ac06_1_schematic.svg.bak
**** Starting to process file svg.pcb.SC03-C2H5OH - Electrochemical Ethanol Module_3d6c130f5103ed2c88216d388420ac06_1_pcb.svg.bak
File
‘part.SC03-C2H5OH - Electrochemical Ethanol Module_e4edef09d1bbeff43f4b735d8d983617_1.fzp.bak’
If you wanted a smd part remove the copper0 definition from line 51
Modified 4: File
‘svg.breadboard.SC03-C2H5OH - Electrochemical Ethanol Module_3d6c130f5103ed2c88216d388420ac06_1_breadboard.svg.bak’
At line 5
ReferenceFile
‘ESP32-S3-LCD-Driver-Board_NEW_UPDATED_LAST1_9b35048fd29b2444e1aa64618f980634_2_breadboard.svg’
doesn’t match input file
‘SC03-C2H5OH - Electrochemical Ethanol Module_3d6c130f5103ed2c88216d388420ac06_1_breadboard.svg’
Corrected
Modified 4: File
‘svg.schematic.SC03-C2H5OH - Electrochemical Ethanol Module_3d6c130f5103ed2c88216d388420ac06_1_schematic.svg.bak’
At line 5
ReferenceFile
‘ESP32-S3-LCD-Driver-Board_NEW_UPDATED_LAST1_9b35048fd29b2444e1aa64618f980634_2_schematic.svg’
‘SC03-C2H5OH - Electrochemical Ethanol Module_3d6c130f5103ed2c88216d388420ac06_1_schematic.svg’
Corrected
Modified 4: File
‘svg.pcb.SC03-C2H5OH - Electrochemical Ethanol Module_3d6c130f5103ed2c88216d388420ac06_1_pcb.svg.bak’
At line 6
ReferenceFile
'ESP32-S3-LCD-Driver-Board_NEW_UPDATED_LAST1_9b35048fd29b2444e1aa64618f980634_2_pcb.svg
‘SC03-C2H5OH - Electrochemical Ethanol Module_3d6c130f5103ed2c88216d388420ac06_1_pcb.svg’
Corrected
Warning 6: File
At line 2
ReferenceFile name
‘ESP32-S3-WROOM-1-N16R8-dev-board_1.fzp’
Doesn’t match fzp filename
‘SC03-C2H5OH - Electrochemical Ethanol Module_e4edef09d1bbeff43f4b735d8d983617_1.fzp’
Warning 32: File
At line 3
Scale is not the desirable 1/1000 ratio from width/height to
viewBox width/height.
Warning 32: File
At line 3
Warning 24: File
At line 8
Font family ‘DINNextSlabPro-Regular’ is not Droid Sans or OCRA
This won’t render in Fritzing
Warning 32: File
At line 3
Error 53: File
At line 286
Bus nodeMember connector18 does’t exist
Error 53: File
At line 290
Bus nodeMember connector17 does’t exist
Error 69: File
At line 8
Error 74: File
At line 443
Connector connector14pin has no radius no hole will be generated
Error 74: File
At line 444
Connector connector14terminal has no radius no hole will be generated
Error 74: File
At line 445
Connector connector13pin has no radius no hole will be generated
Error 74: File
At line 446
Connector connector13terminal has no radius no hole will be generated
Error 74: File
At line 447
Connector connector12pin has no radius no hole will be generated
Error 74: File
At line 448
Connector connector12terminal has no radius no hole will be generated
Error 74: File
At line 449
Connector connector11pin has no radius no hole will be generated
Error 74: File
At line 450
Connector connector11terminal has no radius no hole will be generated
Error 74: File
At line 451
Connector connector10pin has no radius no hole will be generated
Error 74: File
At line 452
Connector connector9pin has no radius no hole will be generated
Error 74: File
At line 453
Connector connector9terminal has no radius no hole will be generated
Error 74: File
At line 454
Connector connector8pin has no radius no hole will be generated
Error 74: File
At line 455
Connector connector8terminal has no radius no hole will be generated
There are likely a number of other problems as well.
The connector which appears to be SMD should be suppressed in pcb as it isn’t through hole as the pads are and thus won’t work there. Schematic is not aligned to the 0.1in grid which it should be (the easy way to do that is to use Randy’s Inkscape schematic extension.)
Pcb looks to be lacking a copper0 layer as the traces for the through hole connectors won’t move to the bottom layer.
It is likely the through hole connectors should be on 0.1in centers like the header connected to them and as noted the SMD connector shouldn’t appear in pcb.
If you wish to fix this up for yourself this tutorial will likely give you the necessary information (as well as were to get a copy of FritzingCheckPart.py and Randy’ Inkscape extension):
Or I can fix up the part for you if you wish.
I sat down in front of the computer today to try to fix it, but there are so many issues. Could you fix it for me? I’d be very grateful!
Sure, for me it is not so difficult because I have done it a lot. A corrected version will be up in a while.
Oh, thank you, Peter!!
OK here is a fixed up part and what I did to it to fix it up. Starting with breadboard. Loaded the breadboard svg in to Inkscape then imported the jpeg image of the board (after deleting the images in the svg, in general images are undesirable as they won’t scale as a svg image will) and scaling it to match the size of the actual part.
Then moved the base rectangle to below the image so the base disappears but the elements are above the image and will appear on top of it. I rescaled the image (which I’m not sure is possible in Illustrator which you appear to be using) to match the desired Fritzing value of one drawing unit being 1/1000th inch.
The image is pulled down a bit but aligned in X to the base so we see the connector and the pads need to move right in X to be in the correct place and so the connector clears the mounting hole on the left (which should be in breadboard!)
As well since these appear to be 2mm headers, the pads need to be realigned slightly as they currently are not on 2mm boundaries.
The next pad should be 14.607mm but is 14.631mm
As well the hole is 0.0382in (which is fine for a 0.1in header, but too large for a 2mm connector) so we need to reduce the stroke-width and radius of the pads to match a 2mm header.
with the space between the pads in Y being exactly 2mm.
Then we want to move the connectors to the bottom of the svg and in to the order that Fritzing expects them (connector on the left top if there was a connector there, in this case on the left bottom) and going up from there. I have tools which will renumber pins if the svg is in this format which is why I did this rather than manually renumber the pins.
Here the pins are renumbered and in the correct order and we are finished with breadboard. So now move on to schematic. I chose to use Randy’s Inkscape extension to do schematic so I need to set it up. Here I set the label to “SC03-C2H5OH” and the size to 1in x 1in (as the that will accommodate all the necessary pins.) It may be worth downloading Inkscape just to use the schematic extension to make schemaitcs as it is much easier than doing it manually.
Then I need to set the number of pins for each side, then click apply to start the application. That brings up the pin name dialog window like this
Here I enter the pin names in the panel (it automatically sets the pin number for me) then click finish.
which brings up a similar window for the right side pins
So fill in the right side pin labels and click finish again.
And it will create the schematic svg.
In this case because of the two headers on the right I need to ungroup the image and move the two headers apart then regroup the image.
Now I can save the schematic svg and move on to pcb. To make pcb I copied the breadboard svg in to the pcb svg then edit it with Inkscape. First I ungroup the svg and delete all the parts not needed in pcb (the bottom connector which won’t connect to pcb and all the text.)
Then change the green rectangle in to fill none, stroke #000000 to make a rectangle the size of the board and change the connectors to the colors appropriate for pcb and the fill from #ffffff to none. The mounting hole (which will be in silkscreen) changes from #ffffff to #000000.
The pads change to fill none and copper color
then the various parts get grouped in to the correct groups
and we can save the pcb svg as completed. Note connectors0-7 (the bottom connector) are not in the pcb svg. As a result we need to manually edit the .fzp file to remove the pcb definitions for those pins. Parts editor at present (and possibly in the future) can not do this so you need to edit the fzp file manually (and of course know how to do it!) To start with the connector looks like this:
    <connector id="connector6" type="male" name="Pin 7">
      <description>VCC</description>
      <views>
        <breadboardView>
          <p svgId="connector6pin" layer="breadboard"/>
        </breadboardView>
        <schematicView>
          <p svgId="connector6pin" layer="schematic" terminalId="connector6terminal"/>
        </schematicView>
        <pcbView>
          <p svgId="connector6pin" layer="copper0"/>
          <p svgId="connector6pin" layer="copper1"/>
        </pcbView>
      </views>
we need to remove the pcbView definition entirely as the pin does not exist in pcb view like this:
      <views>
        <breadboardView>
        </breadboardView>
        <schematicView>
        </schematicView>
      </views>
Once that is done for the first 7 pins we need to adjust the bus definitions (which can be done in parts editor although I find it easier to just edit the file!) The current bus definition looks like this:
 <buses>
  <bus id="3V3">
   <nodeMember connectorId="connector0"/>
   <nodeMember connectorId="connector18"/>
  </bus>
  <bus id="GND">
   <nodeMember connectorId="connector1"/>
   <nodeMember connectorId="connector17"/>
  </bus>
 </buses>
But the connector numbers have changed and we need some more buses. So change it to this
  <buses>
    <bus id="TX">
      <nodeMember connectorId="connector9"/>
    </bus>
    <bus id="RX">
      <nodeMember connectorId="connector2"/>
      <nodeMember connectorId="connector8"/>
    </bus>
    <bus id="VCC">
      <nodeMember connectorId="connector3"/>
      <nodeMember connectorId="connector7"/>
      <nodeMember connectorId="connector11"/>
    </bus>
    <bus id="GND">
      <nodeMember connectorId="connector4"/>
      <nodeMember connectorId="connector10"/>
      <nodeMember connectorId="connector12"/>
    </bus>
  </buses>
Which adds definitions for RX and TX and adds pins to VCC and GND. That completes the changes and results in this part which should do what you want.
SC03-C2H5OH-Electrochemical_Ethanol_Module-fixed.fzpz (7.4 KB)
Hey Peter!! Thank you so much, it seems simple on the surface, but there are a lot of details.
Yes making parts is complex and tends to bite (or simply not work correctly) without warning. It takes a long time to understand all the interactions and get them right. That is why if you only need a part or two it is much easier to let one of us with experience make it for you.
