Routing problems? (Schematic)
As you can see in the above image, the circuit looks fine.
However, if you drag the VRM out, you’ll see this
But if you drag that loose end, uou’ll see
Is this a kind of bug??
maglev_circuit_prototype.fzz (18.9 KB)
Note:
The sketch came from:
and I’m currently doing it from scratch
maglev_circuit_RAPTOR7762.fzz (16.8 KB)
@vanepp any thoughts on this?
It doesn’t appear to be a bug or even wrong, just poorly laid out. Using ground symbols would help a lot. Here I moved the op amp a bit to untangle the connections then right clicked on the ground pin which shows correct connections everywhere.
although there is an error somewhere as this is wrong and it isn’t immediately clear why
Ah! bad layout again. Ground is overlaid on the 5V wire (but not connected to it except visually)
routing schematic correctly should fix all issues I think.
Yeah so in the original thread I’m trying to redo the whole
Can you help me to continue working on it?
Sure, but the sketch appears to be corrupted. At least for me breadboard is appearing blank (and it shouldn’t be.) On load an image of a full size breadboard appears for an instant but when the load completes breadboard is blank (and with parts in the sketch it shouldn’t be!)
moving the scroll bars doesn’t find any parts. Yep it is really broken. Dragging a resistor from core parts in to the sketch doesn’t work.
releasing it which should write it to breadboard doesn’t do anything apparent (no resistor.) I expect the place to start is to create a totally new sketch from scratch and import the hall effect part from the original sketch and go from there.
