Resizing Stripboards using the size option in the Inspector
I have a 56 column 24 row strip board and tried resizing the V4 strip boards in the inspector. I choose the “Basic Single Sided Stripboard”. Then set the strips to lay horizontal. reset the 70 columns to 56 and the 20 rows to 24.
Result:
The direction of the strips is correct as will as the 56 columns. Something is wrong with the row s the increased from 20 to 24.
Please advise.
Jim
Worked fine on Fritzing 0.9.10 on Win10. Either try it again
or maybe clear the user files:
linux
~/Documents/Fritzing/parts
~/.config/Fritzing
Mac
~/.config/Fritzing
I seem to remember a similar problem with some testing I did a year or so ago. That time it was a display glitch. After I saved the sketch, closed and reopened it, everything seemed correct. It was something to do with the exact sequence of row and column size changes.
Which version of Fritzing are you using?
