Please Read when requesting for a part!
(continued and added on from posts above)
The parts submit category is for those whose parts have problems with making their parts or for those who are requesting parts. Before you request a part, please do a Google search of the part with the template: [part_name] fritzing part. Do search within the forums as some search engines (such as Yahoo!) skip some posts.
When requesting for a part, please follow the template below:
Template
Name
Similar work, own work, EAGLEcad files, similar parts
In case there are similar Fritzing parts, you already started work, or there are EAGLEcad files available (.brd, .lbr) please link :link:it here.
This picture shows the part from above, so that is easy to see where connectors should go, and which diameter they have.
Photo or vector graphic, no links here, please.
Please, please :pray: add a link to the PDF of the manufacturer’s datasheet
THIS IS COMPULSORY!!! TOO MANY USERS MISS THIS SECTION!!!
Footprint (optional)
E.g. SOT23-5, TO-220.
:bangbang: Please do not just give images and veer away from the template!**
(Note: From 2026 onwards, EAGLEcad will be phased out)
@vanepp, @landracer or anybody, please global pin this topic (as most users are happily ignoring the template…)
As an add on, if the datasheet is not available (most likely), then supply a website where the part was taken from. It must contain the connector info and part dimensions
