Please Read when requesting for a part!
(continued and added on from posts above)
The parts submit category is for those whose parts have problems with making their parts or for those who are requesting parts. Before you request a part, please do a Google search of the part with the template: [part_name] fritzing part. Do search within the forums as some search engines (such as Yahoo!) skip some posts.
When requesting for a part, please follow the template below:
Template
Have you done a Google Search of the part
fritzing part [part name]
e.g. fritzing part l298n driver module
Yes, not found
No/Unread (we may ignore this part request if ticked)
Name
Similar work/own work
In case there are similar Fritzing parts, or you already started work, please link/upload it here:
High-resolution top view, flat image
This picture shows the part from above, so that is easy to see where connectors should go, and which diameter they have.
Photo or vector graphic, no links here, please.
Datasheet/Website
Please, please add a link to the PDF of the manufacturer’s datasheet/the website where the part was taken from (must have connector information, name, and part dimensions)
Footprint (optional)
E.g. SOT23-5, TO-220.
(required fields coloured in red :red_square:)
Please DO NOT just give images/descriptions. If you do not fill in required fields, we might not entertain this part request
Have you done a **Google Search** of the part
Yes, not found
No/Unread (we *may* ignore this part request if ticked)
**Name of the part**
Name
**Similar work/own work**
**High-resolution top view, flat image**
**Datasheet/Website**
Please, please **add a link** to the PDF of the manufacturer’s datasheet/the website where the part was taken from (**must** have **connector information, name**, and **part dimensions**)
**Footprint (optional)**
Please **DO NOT just give images/descriptions**. If you do not fill in required fields, we might not entertain this part request
@vanepp, @landracer or anybody, please global pin this topic (as most users are happily ignoring the template…)
As an add on, if the datasheet is not available (most likely), then supply a website where the part was taken from. It must contain the connector info and part dimensions
