Welcome aboard! They make pcbs that match breadboards like this one (and many others)
https://www.amazon.ca/Solderable-BreadBoard-matches-tie-point-breadboards/dp/B0040Z6OK6
from a google search for “breadboard protoboard pcb”
which may do what you want easier. There are also components (usually named top view) that are specifically designed for perfboard use that only take up the space they occupy in breadboard (normal components are quasi 3d and larger than they appear in life. Blue made a bin file of a lot of them here
Some folks also use pcb view to make perf board designs as components there are typically life size. It looks like you are using RJ45 connector, is that what you intend to use in the final project? There are other types of connectors available if not.
