Photocell (ldr) module
can someone help me to find this module for fritzing? please :slight_smile:
There is no such module just normal " LDR" .BUT IF YOU KNOW THE PCB YOU CAN MAKE THIS IN" FRITZING" AND USE IT OR USING INKSCAPE .
Welcome aboard! A google search for ā€œfritzing part fritzing part ldr moduleā€ in the images section indicates this is a keyes KY-018 module and a search for ā€œfritzing part KY-018ā€ turns up
which may do you.
Thank you sir, youre very helpfull… I forgot to keyes bundling froduct… Thanks again… :slight_smile:
Your part has a number of problems:
$ FritzingCheckPartw.py part.CK-07_aec927b6e775740244da0b1d1ca98dc8_5.fzp
**** Starting to process file part.CK-07_aec927b6e775740244da0b1d1ca98dc8_5.fzp
**** Starting to process file svg.breadboard.CK-07_18dbd62cba412dbc7bd36772c10be727_27_breadboard.svg.bak
**** Starting to process file svg.schematic.CK-07_18dbd62cba412dbc7bd36772c10be727_27_schematic.svg.bak
**** Starting to process file svg.pcb.CK-07_18dbd62cba412dbc7bd36772c10be727_27_pcb.svg.bak
File
ā€˜part.CK-07_aec927b6e775740244da0b1d1ca98dc8_5.fzp.bak’
If you wanted a smd part remove the copper0 definition from line 63
Modified 4: File
ā€˜svg.breadboard.CK-07_18dbd62cba412dbc7bd36772c10be727_27_breadboard.svg.bak’
At line 3
ReferenceFile
ā€˜CK-07breadboard.svg’
doesn’t match input file
ā€˜CK-07_18dbd62cba412dbc7bd36772c10be727_27_breadboard.svg’
Corrected
Modified 4: File
ā€˜svg.schematic.CK-07_18dbd62cba412dbc7bd36772c10be727_27_schematic.svg.bak’
At line 3
ReferenceFile
ā€˜CK-07schematic.svg’
ā€˜CK-07_18dbd62cba412dbc7bd36772c10be727_27_schematic.svg’
Corrected
Modified 4: File
ā€˜svg.pcb.CK-07_18dbd62cba412dbc7bd36772c10be727_27_pcb.svg.bak’
At line 3
ReferenceFile
ā€˜CK-07pcb.svg’
ā€˜CK-07_18dbd62cba412dbc7bd36772c10be727_27_pcb.svg’
Corrected
Modified 6: File
At line 21
Added inherited stroke-width value
Modified 6: File
At line 22
Warning 6: File
At line 2
ReferenceFile name
ā€˜fc-51_85d98481ce3be6f2e9b641181c0f798b_1.fzp’
Doesn’t match fzp filename
ā€˜CK-07_aec927b6e775740244da0b1d1ca98dc8_5.fzp’
Warning 14: File
At line 76
terminalId missing in schematicView (likely an error)
Warning 14: File
At line 91
Warning 14: File
At line 106
Warning 14: File
At line 121
Warning 11: File
At line 129
Type female is not male (it usually should be)
Warning 14: File
At line 136
Warning 14: File
At line 151
Warning 36: File
Connector0 doesn’t exist. Connectors should start at 0
Warning 35: File
Connector0 doesn’t exist when it must to stay in sequence
Warning 19: File
At line 1
Height 103.15 is defined in px
in or mm is a better option (px can cause scaling problems!)
Warning 19: File
At line 1
Width 39.69 is defined in px
Warning 19: File
At line 1
Height 28.8 is defined in px
Warning 19: File
At line 1
Width 64.35 is defined in px
Warning 19: File
At line 1
Height 40.41 is defined in px
Warning 19: File
At line 1
Width 91.43 is defined in px
Error 69: File
At line 9
Error 74: File
At line 20
Connector connector4terminal has no radius no hole will be generated
They can all be fixed by the information in this tutorial
Randy’s Inkscape schematic extension (in the tutorial) is the best way to make correct schematics (assuming you use Inkscape.) You will likely need to rescale the svgs after changing the dimensions from px to inches (also detailed in the tutorial.)
