50mm Radial Cooling fan,
12V 2-point Pin DC 0.13A.
Made of high quality PBT 30% glass line VO
Bearing is high precision, long life and low noise.
Excellent for cooling heat sinks on hot ends, prints, or other cooling needs
Specifications:
Model : 5015 Vortex Turbo
Material : PBT 30% glass line VO
Speed (RPM) : 7000±10%
Operating Temperature : 10° to 60° C
Operating Voltage : 12 V DC @ 130mA
Air inlet size : 31mm
Outlet size : 18 x 13 mm
Mounting Screw Hole Diameter : 4mm
Cable Length : 30 CM
Dimensions in mm (LxWxH) : 40 x 40x 13
Weight(gm) : 25g
