Part Request - AQV258 PhotoMOS Solid State Relay
Hi Friend,
Really appreciate if you can provide the fritzing part file. THANK you.
Panasonic AQV258 PhotoMOS Solid State Relay
Previous work, similar parts
[https://www.mouser.com/datasheet/2/315/semi_eng_he1a_aqv25-1299756.pdf](https://Panasonic AQV258 PhotoMOS DataSheet)
6-Pin DIP6
There doesn’t appear to be such a part but you can make yourself one by using the generic IC in core parts and editing the pin labels.
Thank you @vanepp. I made one via generic IC like what you suggested but still missing the internal LED and MOSFET inside the AQV258 schematic.
You would need to make a custom part to get the schematic. This tutorial will tell you how to do that, but it is fairly complex (the generic IC is much easier if less complete …) These days I usually use Randy’s Inkscape schematic extension to make schematics, but it doesn’t work for this type of schematic so you have to make that in Inkscape for yourself (which is quite complex.)
