Need part for Sensata-Crydom ED06D5 Relay
Sensata-Crydom ED06D5 Relay attached to PCBSED Through Hole 5 Position Socket
Previous work, similar parts
The Fritzing part for relay-t9a-2 appears to be the closest premade part I can find
https://www.sensata.com/sites/default/files/a/sensata-ed-series-dc-output-plug-in-ssr-datasheet.pdf
https://www.sensata.com/sites/default/files/a/sensata-ed-series-sockets-accessories-datasheet.pdf
I’m struggling with creating a new part from scratch. I also sent in a request to have this part made through the form on the website but haven’t gotten a response. Can anyone help me with this? Thanks in advance.
This part may do what you want. Their data sheet lacks pin numbers in the socket and lacks what view (from the top or the bottom) a particular diagram is so the part is entirely a guess and may be wrong. Before ordering boards print the pcb footprint out at 1:1 scale and compare it to a real part and verify the pins are in the correct place.
Replace the part to correct the pin spacing slightly from the new information below. Note if you have already downloaded the original part you will need to delete the part in the mine parts bin by right clicking on it then selecting delete part. After that to actually delete the part you need to shut down Fritzing and answer yes to save parts and yes to save parts bin (you can answer no to save the sketch though.) On restarting Fritzing it should let you load the corrected part.
relay-ED06D5.fzpz (17.0 KB)
Peter,
I appreciate your prompt response. I can provide a few more links if they could be of any help.
These are from the manufacturer:
https://www.sensata.com/products/relays/ed-series-dc-output-plug-ssr-ed06d5
https://www.sensata.com/products/relays/ed-series-sockets-sockets-pcbsed
I’ll also attach Digikey links, because downloading the stp file was easy:
https://www.digikey.com/en/products/detail/sensata-crydom/ED06D5/2665161?s=N4IgTCBcDaIKIBEAMA2BBWEBdAvkA
https://www.digikey.com/en/products/detail/sensata-crydom/pcbsed/2665177
Not sure if these links will be helpful in clearing up any confusion. Otherwise, thank you so much for providing this part for me!
OK, the new information gave me a better image of the socket, there are still no pin numbers listed but I could at least see that in deed the views are non standard. This is the socket from one of the new data sheets which indicates the image on the left is viewed from the bottom (which is what I had assumed) and thus needs to be flipped in horizontal to be viewed from the top which Fritzing is expecting. As well I managed to screw up the spacing between the pins a bit which is now corrected.
Now when I import the above image and scale it correctly the pins line up correctly with the image (the image here is flipped in horizontal so it is the view from the top of the socket.)
I have replaced the part in the post above with the new one. As the edit comment there says, if you have downloaded the part already you will need to delete it and then shutdown Fritzing (to really delete it) before it will let you load the new part. The socket still has no pin numbers listed (only the relay itself has the pin numbers) so checking that the socket pins go to the expected pin on the relay it self would be a good bet. I think it is right as it stands but it may not be.
I looked around and was able to find an extra one relay/through hole adapter. I took a picture of the bottom of both of them.
So your part, from a top down view, appears to be correct and the pins are labeled correctly as well.
Thanks again for your time and your assistance, Peter.
