Need part for pico prototype board
Monk Makes Pico Proto Board
Previous work, similar parts
MonkMakes | The company website for MonkMakes Ltd.
X Breakout board, sub assembly, plug in module (A)
Insufficient information available to make a part. There is no indication of which pins are bussed. I would assume (without proof) that the power busses are a bus. It is unclear what the solder pins for the power busses connect to when soldered. It is unclear if the pico pins are bussed to the pins on the pico (although that seems likely) and their documentation doesn’t provide any information. It is also a very complex part to make even if there was sufficient information, but the lack of information is fatal.
The 3v(+), GND(-), and pico pins are bussed. The lower strips (21-30) are bussed on each side. So rows 21-30 are bussed for the 6 pins on the left side and the 6 pins on the right separately. kind of like a breadboard.
So the busses looks like this?:
Presumably the power busses are only bussed together but not to the GND or 3V Pico pins if the solder bridges are not connected?
That looks correct!!
@RAPTOR7762 will make a part for you.
@JesterOMA75 This should be the part you want
Monk Makes Pico Proto Board.fzpz (13.0 KB)
Note that default grid size may not align pico and other components properly to the board pins, as fritzing will choose the reference connector to align with at random
To fix, please set grid size to 0.05in before placing the components
@JesterOMA75 Fixed part
Fritzing uses the first connector as reference for grid alignment.
This is a problem with parts like this, since a 0.1 grid size will either match the power lines at the side, or the board connectors in the center, and these are set 0.05 inch apart.
Fritzing should use one or the other, but always the same, not at random. When creating the part, you can decide by putting the reference connector first.
Using a half size grid (50mil) is a good workaroud for the issue.
From experience that is not true. If you load a part with off grid pins multiple times Fritzing will sometimes change the reference pin and select one of the offset pins making all the pins intended to be on the grid offset by the space of the non aligned pin it chose as a reference. This part provides a good demonstration (I believe there is an issue open on correcting this on github as it is very annoying!) Loaded the part and dragged it in to breadboard. Pin 0 is not aligned to the grid the power strips are:
A zoomed in (with rulers added to demonstrate the offset):
Now delete the part and shutdown Fritzing (so it will need to be reloaded, because I think this happens at load!.) Luckily for me this one aligned correctly (you sometimes need to go through this cycle a number of times to get a misaligned part.)
This time the power rail is misaligned 0.05in and pin0 is on the grid. A zoomed in and ruler version to show that.
This time pin 0 is correctly aligned to the grid. Don’t know why this happens but it is very annoying when there are parts with misaligned pins.
Fantastic! Thanks for your work!
