How are you planning to use the sensor in Fritzing?
It appears that the sensor presents externally as an analog voltage. With the example shown, it acts the same as potentiometer. As far as the circuit (schematic) goes, that would be an accurate representation. There are no pins on the board that would connect directly to a pcb. Connections to it, both for the probe, and for measurements, are through cables. Which means no pcb view is really needed. The same for breadboard view. It is just 3 wires, power, ground, and sense, leading off the project. Again, a potentiometer would simulate that well. Or any 3 terminal analog sensor. One of the temperature sensors would work. Just change labels to what works for your project.
Since you say “tds” I assume you mean the part file from the other post thread that @vanepp referenced above. That downloads correctly for me. I can’t actually open it, because it is already in my bin. Fritzing does not allow 2 parts with the same internal ID to be loaded at once.
What link are you trying to use? What happens? “can not download” does not say much. What message do you get?
Try the download again. It looks like the forum software was just restarted, possibly indicating it was malfunctioning and it may have been blocking downloads.
