Does someone have this fritzing file? I need it for my project report. thanks
A google search of the form “fritzing part mh breadboard power supply” says try here:
I recall working on a breadboard power supply part, but it had a different layout than the one in the image. Without a usb connector, and using shorting jumpers instead of switches to select 3.3 or 5V to the rails.
I want it to be as similar to the image as possible for better presentation in the report. Thank you for your answer anyway.
Then you would need to supply more information such as web site where the device is available with physical dimensions and information on all the connectors and what they do. Pictures are essentially worthless when searching for parts.
Sorry for not providing more detailed information. I purchased it from another e-commerce platform, but it’s exactly the same as the one in the picture. Below is the sales link I found on another platform. MH Breadboard Power Supply Module | Keszoox
mh-breadboard-power-supply-module.fzpz (14.5 KB)
Thank you so much! This is exactly what I needed. May I ask how to switch between 3.3V and 5V?
I believe the 2 switches on the board switch between 3V3 and 5V from the markings on the board, though I don’ t have one to verify that.
