Hello, I have been trying to make the part max30101 but I cant find another part in fritzing with a similar package (OLGA). This is the datasheet https://www.analog.com/media/en/technical-documentation/data-sheets/max30101.pdf . I found this past post but its just a breakout and all I need is the chip Max 30102 - Help!
This should do what you want. Note you need to print the footprint out at 1:1 scale and check it against a real part as the 14 OESIP1 footprint doesn’t match the footprint referenced in the datasheet. I used the datasheet footprint.
MAX30101.fzpz (5.3 KB)
How do I print it 1:1 scale?
File->export For Production->pdf
and then print the pdf (probably on transparency so you can see the footprint) should do it.
