Hi!
Anyone has this part?
There doesn’t appear to be one, but it is a minor change to a more pins version I made for someone some years ago so here is a part. Download the .fzpz file then File->Open->gy-max30102-module.fzpz will load the new part in to your mine parts bin ready for use. Note to get the mounting holes drilled you need to drag a hole in to the sketch in pcb view (the holes in the part are only on silkscreen) and set the size correctly.
gy-max30102-module.fzpz (5.3 KB)
