This is possible but a lot of work with little gain. The UPS part will be mostly hidden under the RPI board and whatever other hats are installed with only 4 connectors (GND, 5V, SCL, SDA) to the gpio pins) It will then show up in schematic (but likely not pcb as it isn’t useful there) as with the camera an image file is probably the best bet here assuming you want it to appear in breadboard.
Is it possible to just have a part that looks like it, so that I could include it in the connections. I am new to Fritzing and I am unfamiliar on how to make a part. i just want to include it in the connections that’s all.
Thank you so much for your help. Really means a lot.
