Looking for Tr-Htse Soil Vwc Sensor Temperature
Hi everyone,
I’m looking for this
Soil Moisture Sensor
Tr-Htse Soil Vwc Sensor Temperature Measuring Instrument Conductivity Sensor 4-20mA Feildsout Multi-Depth Soil Moisture Sensor
Previous work, similar parts
In case there are similar Fritzing parts, or you already started work, please link it here. N/A
Connection diagram
The official documentation of the part manufacture is linked here: Tr-Htse Soil Vwc Sensor Temperature Measuring Instrument Conductivity Sensor 4-20mA Feildsout Multi-Depth Soil Moisture Sensor - Multi-Depth Soil Moisture Sensor and Conductivity Sensor 4-20mA
I’m looking for the sketch of this sensor.
It has four wires
Red (V+): Power
Black (G): Ground
Blue (O1): Output Signal
Brown (O2): Output signal
This part should be close enough. Your output isn’t RS485 but rather voltage but the pins are there.
Hi Peter,
I agree its close. but you know the words written on the JXBS-3001-NPK-RS will bias the reviewer. The actual sensor looks like this
Not a clear enough picture to do anything with and no data sheet that I can find on the referenced part. Without more information you appear to be out of luck.
Oh dear, the manufacturers just provided a webpage.
This is all I can see and find
Even blown up this is unreadable and I can’t find anything better online.
without knowing what you want on the label a part isn’t possible.
My apologies, Peter!
I got its labels are right here
OK that should be enough. to do the job. It will be up in a while.
Thanks much Peter, I will be waiting
Tr-Htse-Soil-Vwc-Sensor.fzpz (4.8 KB)
This is incredible, You are the best. thanks a lot.
I can’t thank you enough.
Onan
For these exists and functional, but BB ‘looks wrong’ cases, can we put up a general suggestion to overlay an image in BB view? No special part needed.
Especially for things like sensor heads.
Probably a good suggestion, although in this case the output pins are also different (a voltage rather the RS485 output) making schematic somewhat wrong as well . Still something to consider in future (assuming I remember to do so of course :slight_smile: .)
