Looking for mini toggle switches (MTS-102 / MTS-202 / MTS-203)
Some work was already done on these toggle switches here:
Note that they can’t be used on a breadboard directly.
A typical solution is a flyboard ( a very simple breakout board).
So, you’d draw the breadboard view of the switch on top of a PCB, that has breadboard compatible pins on the bottom side.
