Hello, could anybody help me with a LILYGO T-ETH-Lite-ESP32?
For more information here is the github link for the part.
This part should do what You want. As usual the mounting holes are not drilled by default. If you want the mounting holes drilled you need to drag a core/pcb/hole in to the sketch then set the appropriate size.
lilygo-t-eth-lite.fzpz (16.4 KB)
