hi, i need help for driver DM556 part. Some time ago, i just saw the picture of DM542 not include the fzpz file. In terms of body appearance as well as the microstep and current tables, both are similar, the DM556 and DM542. The only difference I can see in the image is the “DM542” label. So, does anyone happen to have the FZPZ file for the DM556 or DM542? Thankyou guys
is it similar to this part? I could easily adapt it.
Do you have a link to the datasheet?
Best regards, Harald!
hi Harald, thankyou and yes it is similar. And at the picture the difference is just the DM542 label, meanwhile, what I have is the DM556. All the terminal and the table are same.
If the table doesn’t need to be changed, I’ll get on it today.
Cheers, Harald!
the table on the device does look a little different though. If that’s not an issue, it should work.
DM556.fzpz (9.4 KB)
Best, Harald!
Thankyou so much harald. sorry for late to looking back this forum. But once again thank you so much. Have a nice day sir ![]()
Great when it works out!
Best of luck, cheers Harald!
