Looking for DB15 connector with two rows of pins. need PCB only
OK here is a part that should do what you want.
db15.fzpz (8.6 KB)
it has all 3 views and pcb is a corrected version of your svg (the spacings were slightly off in your svg and have been corrected.) You may want to print out the pcb footprint at 1:1 scale and make sure it will do what you want. The holes for the wires are 0.035in and the nonconn holes will be drilled and have the copper pads.
