Hi, does anyone have a Fritzing part file for an Electromagnetic Lock such as this one?
Thanks
Thanks
This is likely as close as you are going to find.
It’s not a lock @isaac7437, but a control access system (a “sensor” to know if a door is closed or opened).
What @vanepp pointed you at IS a lock, if that’s what you are really looking for.
Regards!
rs-pro-192-4535_door_lock.fzpz (4.8 KB)
Actually it is a lock just like the one I pointed to but with a somewhat more complicated connection structure which needed a new part as the original does not have the sensor connections.
Thank you, that’s great. ![]()
Hi everyone, I’m having trouble resizing the door look that was shared here. Can anyone assist me with that? I’d appreciate your help!"
If you provide the data sheet for the lock you want it can be done.
