Looking for ACS724 (high current sensor) and HW-532 (high current mosfet)
Hi everyone! Is anyone interested in helping me and the community build these parts?
For future reference this post should be in parts help not parts submit. This part should do for the ACS724-LLCTR-40AB
ACS724-LLCTR-40AB.fzpz (6.2 KB)
There isn’t enough information available to make a Hw-533B part. I can’t find any site that gives the dimensions of the module (or at least that match the jpeg image of the module.) Without that it isn’t possible to make the part. If you have one and can measure (exactly!) the width and height of the board, that should do what I need.
I assume the pads on the right should be for a 0.1in header (since it appears to come with one) but I need the length and width of the board itself to be able to scale the jpeg image correctly to place the components and connectors and I can’t find that in a search.
You got lucky, I found a site with a better jpeg image and was able to work out that the connectors for the load screw terminals are likely 3.5mm, the associated header is 0.1in and on the other side the inside header is 0.1in and the right most connector is 2mm. Which creates this part which should do what you want. Before ordering boards print the pcb footprint out at 1:1 scale (the default) and compare it to a real part to make sure the pads are in the correct place and the outline is correct. As well the mounting holes are not drilled in pcb by default. If you want them, you need to drag the core parts→pcb->hole part in to the sketch, place it over the mounting holes in pcb view and use inspector to set the hole size appropriately.
HW-532B.fzpz (7.7 KB)
Thanks for the parts. There is a slight size difference. I checked the dimensions with my caliper and is measurements on the board is 33mm x 16mm. The small pin header holes are 2.54mm gap but those holes are not breadboard friendly as the output pin holes are a slight offset.
The cyan guidelines on the PWN and GND pins are 2.54mm spacing and we can clearly see that the output pins and not in line.
Also you have submitted a similar part NOYITO Opto Isolated MOSFET (PWM) Driver - LR7843
and that part dimensions are correct I think. I think these modules are all having the PCB dimensions with just different MOSFET configurations.
It would be very helpful if you can change the board dimensions for the module.
I tried with this SVG, I don’t think the holes are correct.
mosf_01c
