I think we should assume the issues are related to:
- custom parts that
- are not fully supported by the parts editor
- I had switched (possibly back and forth?)
This particular error is probably due to oversight on my part (ie. not seeing the ratsnest) WHILE also introducing some larger changes to a sketch THAT I had not tried on bb.
I’m usually laborious and first do assembly of changes on breadboard before I do a larger change. This time, since it ‘seemed’ straight forward AND I had to rework the sketch anyway, I charged ahead with two things at once. 1. fix the part, 2. modify the sketch. Muddies the waters.
It’s very likely that I’ll produce and next iteration within 10 days and I can continue from this sketch as a test. I wouldn’t chalk it up to routing errors, per se, just yet.
