KY-040 Rotary Encoder breakout board part
There probably isn’t one. This is more or less the standard way to make such parts (although I often don’t bother.) The wires connect to the end of the pins because that is where the connectors are which is again standard. You can edit the svgs to make whatever modifications you like (instructions are here although they are fairly complex
