Is there a schematics or a built D24V10F3 I can use
Pololu 3.3V, 1A Step-Down Voltage Regulator D24V10F3
Has anyone built this voltage regulator yet. I’m looking for this part, but only find the 500mA step down only. If anyone have one made can you please post one that I can use. Thank you.
A google search of the form “fritzing part D24V10F3” (which is the best way to find parts) says there is one here (a;though it is the 5V version probably):
The project runs more than 500mA so I will need a 1A and I don’t want to burn my circuit.
Fritzing doesn’t care how much current your project needs (but you do in real life.) It is likely (although I didn’t check that) that the listed part has the same connections as the higher voltage one which is all the Fritzing cares about. As a result it isn’t worthwhile to make a new part when there is likely one that will do.
okay, thank you for the clarification.
