IR2104 Gate Driver - PART REQUEST
IR2104 Gate Driver
Previous work, similar parts
I was unable to find an existing IR2104 part in the official Fritzing repository or among community contributions. No suitable substitute (e.g. IR2101) matches this pinout exactly.
(attach your ir2104-topview.svg or high‑res PNG here)
This shows the DIP‑8 package from above, with 2.54 mm pin spacing and ~0.7 mm hole diameter.
Official Infineon IR2104 Gate Driver datasheet (14 pages):
DIP‑8 through‑hole (7.62 mm pin‑to‑pin spacing)
You can make one for your self using the generic IC in core parts. Instructions are in this tutorial
Or if you need SOIC you can use defualt package here
