Part creation howto part13-ICs
This is a continuation of
As I lately decided to merge this tutorial with Peter’s part creation series, I left the links behind. Never mind, I’ll just leave them there as a reminder.
In this tutorial, you are going to learn how to make Fritzing Parts.
You need these apps ready:
1. Fritzing (of course)
Download Fritzing here:
https://fritzing.org/download/
Alternative payment method (without using PayPal):
https://fritzing.org/download?payment_method=alt
2. Inkscape
Download Inkscape here:
3. Inkscape Fritzing Schematic Extension
Download it here:
Now, let’s proceed with chapter 1.
(Note: The tutorials have been tested with Fritzing 0.9.3b, Fritzing 0.9.10, and Fritzing 1.0.4. For the best result, use versions above 0.9.10)
Chapter 1.1: ICs (DIP package)
You are going to be creating an MCP3008 IC in this chapter
The main reason why I created this part is because the one by Adafruit
doesn’t look very nice (the schematic is gigantic!)
When you access the datasheet here:
You’ll see that on the first page, there is the pinout of the part
Please save this image somewhere as you’ll need it later.
Then, follow the steps below.
  1. Open Fritzing, go to the breadboard tab and delete the breadboard.
  2. Drag out the “Generic IC” part from the core parts
  3. In the Inspector, change
    to
    (Changes are boxed in green. If you are creating another IC, please change the fields above accordingly.)
  4. Press Edit Pin Labels
  5. Change
    to
    (If you are creating another IC, be sure of the pin labels and change the fields accordingly.)
Once done, press save.
  1. Right-click → Edit (new parts editor)
  2. Check the order of the pins in the Breadboard, Schematic, and PCB views.
  3. Go to the “Icon” tab
  4. File → Reuse Breadboard Image
  5. Go to the Metadata tab
  6. Change
Title: DIP 16 pins
Author: Fritzing Part-o-matic
Description: A DIP stand-in part for whatever IC you want. With 16 pins on a 300mil dual inline package (DIP) footprint.
URL:
Family: Generic IC
Variant: variant 2
Properties:
chip label: MCP3008
package: DIP (…) [THT]
pins: 16
Tags: DIP, fritzing core
to
(note: there is an error in the image. It should have been "variant: MCP3008 and not “MMCP3008”. The part label should also be “U”.
Note 2: the URL has been cut short. Please copy and paste the full URL)
  1. File → Save as new part → change “prefix#0000” to “mcp3008” (without the quotes) → OK
Time for checking
To check your part, you must connect each pin to a pin header. I reckon you do so in the schematic view like this
Then in the breadboard and PCB views, align the IC and the header like this:
For the schematic view, the wire cannot terminate to the centre of the pin, and the label should not fly out of the box.
If your Schematic not work, please use Randy’s Inkscape Extension. Instructions are in the forum post
Note that you have to change the height to 0.9, and the width to 0.5 (or 0.6). Please also set the no. of left and right connectors to 8 (pins on each side)
Model Answer
After following all the steps above, you will get a part like this:
MCP3008.fzpz (7.2 KB)
I have changed the module ID of the part, so you can compare your part against mine.
Chapter 1.2: ICs (TO-220 package)
A year back, I requested a TC74 part.
This time round, I decided to adopt the TO-220 Package Design from the Voltage Regulators Bin (not found in part versions before Fritzing 0.9.10)
So I compiled some breadboard view SVGs (for your future use) and here they are (right-click on the image → Save as…)
TO220_3pin_bb
TO220_5pin_bb
TO220_7pin_bb
Now, let’s start making the Fritzing Part!
Start with a Generic IC
Drag out a Generic IC from the Core Parts
Then in the inspector view, change from
to
(Changes are boxed in green. Note that there is an error in the image. The no. of pins should’ve been 5. If you are making another IC, please change the fields above accordingly)
Click “Edit Pin Labels”
Change
to
Once done press save.
Now, right-click the IC → edit (new parts editor)
Breadboard View
Please download the SVG here:
svg.breadboard.prefix0000_bbf502a81eb715747a8918e4ce98ae99_2_breadboard
File → Load Image for View → Select .svg file → Open
It is good practice to change the family from Generic IC first before loading image for view so that the Part-o-matic will not get confused (I think a few users experienced schematic view problems because of this!)
Then check if the pins are configured correctly.
Schematic View
I think the parts factory’s schematic looks fine, so you can use it.
Should your Schematic not work (i.e. the label flies out of the box, etc.), please use Randy’s Inkscape Extension.
PCB View
Leave it as it is.
Icon View
File → Reuse breadboard image
Metadata
Change
to
Once done, save the part. Then follow the testing steps above.
Remember: The wire should never terminate at the centre of the pin in the Schematic view. Your schematic cannot lack terminalIDs (if you’re using the extension.)
If you have/there are any issues, please post!
