ai thinker VC-01
Are you looking for the SMD module or the breakout board (the kit?)
the breakout boar (kit) ![]()
This part should do what you want. Note the mic and speaker connectors don’t appear in pcb, and the pcb pad positions may be wrong (as they were set from a jpeg image.) You need to print out the pcb footprint and compare it to a real board to verify if the pads are positioned correctly (and tell me how much the pads need to move to be correct.) As well the mounting holes are not drilled by default, they are only in silkscreen. If you want mounting holes drilled you need to drag a pcb/hole in to the sketch, place it over the hole in silkscreen and set the size appropriately.
ai-thinker-vc-01-kit.fzpz (18.6 KB)
Thanks, Peter
I appreciate this so much
Peter, I’ve had a go at making my components for fritzing using Inkscape, but they keep getting annoyingly lost. You don’t have a template I could use to make life easier, do you?
If you’re creating ICs, please refer to the tutorial here:
Whole series, until part12 I think.
Part creation in general is complex. It took me 1 year to master my part creation skills. Till now, I still make careless mistakes.
Maybe when you are done making the parts, you can share them with us and we can help you fix them
