Grit
April 7, 2023, 12:20pm
I want DFRobot or Keyestudio TDS meter fzpz file.
Grit
April 7, 2023, 12:22pm
Who can do for me? I need to use tds meter to do project and it dont have tds meter part in fritzing so I want fzpz file of tds meter.
vanepp
April 7, 2023, 2:32pm
#3
First a pointer to a web site that describes what you want would be more useful. Then a google search of the form “fritzing part tds meter” turns up several hits for parts which may or may not be what you are looking for since there is almost no information in your post.
That did the job, thanks! I grabbed the bb image of a BNC connector from core parts, rescaled it a bit to match the space (the barrel isn’t long enough but close enough!) removed its connectors and pasted it in to bb giving this:
[PH_meter_bb]
which with your background makes this about as good as it gets I think. This is the latest version of this part with the above change in it.
PH_meter_1.fzpz (65.6 KB)
In this case the “board” is made up of 4 line paths (in a rectangle) and 4 arcs (th…
Grit
April 10, 2023, 2:20am
#4
TDS not pH pH I see it already but no TDS. TT
vanepp
April 10, 2023, 5:11am
#5
Then you need to provide a web site for whatever it is you do want …
