How to make template files
Hi
Is there a tutorial on how to make template files like some members do with these files?
breadboard
icon
pcb
schematic
How are these files compiled into a file with the fzpz extension?
Note that I know of (although the graphics standards set the visual format and spacing.) The best way is usually to start from a part that is similar (and which hopefully has correctly formatted files!) and modify that being careful to maintain the format (such as layerIds.) FritzingCheckPart.py will flag errors that will cause problems. This tutorial set may help as well
I don’t think this is documented anywhere. The files need to be in this format
part.fc-51_1.fzp
svg.breadboard.fc-51_85d98481ce3be6f2e9b641181c0f798b_1_breadboard.svg
svg.pcb.fc-51_85d98481ce3be6f2e9b641181c0f798b_1_pcb.svg
svg.schematic.fc-51_85d98481ce3be6f2e9b641181c0f798b_1_schematic.svg
This is the part template directory that I use to make parts. The files are incomplete (no connectors for instance and incomplete fields that need to be completed in other cases.) I have tools (not so far published) that create the correct number and format of connectors and I know what needs to be changed to make a complete part and keep FritzingCheckPart.py happy with the result (usually after an error or 3 though when I forget to do something or make a typo.) To create a .fzpz file you zip the 4 (sometimes 5 if you have a separate icon svg which is possible) into the .fzpz file. The alternate format is 4 directories (without the prepended part. or svg.layerId. parts of the above like this from core parts:
Fritzing\fritzing-parts\core
3_Axis_Accelerometer_Breakout___MMA8452Q.fzp
which contains the .fzp files then
Fritzing\fritzing-parts\svg\core\breadboard
which contains the breadboard svgs
such as
3_Axis_Accelerometer_Breakout___MMA8452Q_BB.svg
(note the lack of svg.breadboard. on the file name!)
Fritzing\fritzing-parts\svg\core\icon
which contains the icon svgs (a copy of the breadboard svg if there is no icon svg.) like this
3_Axis_Accelerometer_Breakout___MMA8452Q_Icon.svg
Fritzing\fritzing-parts\svg\core\pcb
which contains the pcb svgs like this
3_Axis_Accelerometer_Breakout___MMA8452Q_PCB.svg
and
Fritzing\fritzing-parts\svg\core\schematic
which contains the schematic svgs like this
3_Axis_Accelerometer_Breakout___MMA8452Q_Sch.svg
The svg file names are defined in the .fzp file (and must match in case to be valid on all operating systems!) FritzingCheckPart.py will accept and deal with either format.
Hope this helps!
thank you for your help
