I’m trying to create a part with non-round through holes but the holes are not showing up in any gerber viewers. What am I doing wrong?
PJ398SM.fzpz (5.1 KB)
I saw Peter mention this here.
Fritzing doesn’t support non circular holes in parts. The only thing you can do is use an outline svg in the sketch to produce slots and that is a PITA and can’t be moved. Your best bet is to use a hole big enough to cover the slot.
Thanks Peter. That sure is a PITy! Lol.
Here’s a “round hole” workaround part for the same (PJ398SM) Jack socket:
PJ398SM-rh.fzpz (5.2 KB)
Kevin.
