Help fixing schematics error on 18650 battery pack
Hello all,
II found this 2x18650 battery holder (2x_18650.fzpz (11.2 KB)) in this thread: 18650 Battery Holder Part Design - #32 by just_randy - problem is just that it seems like the schematics is inverted when choosing the 7.4V version.
I don’t mind trying fixing it myself, but I’ve tried to look in the parts editor and I tried unzipping the .fzpz file and look in the fzp (xml) file, but I cannot figure out what would make it act like that. I feel like I’m missing some basic knowledge (which I guess is fair since i started on this wednesday :P).
Any assistance would be great!
For comparation here are the battery holder mentioned above together with the build in AA battery.
“But you can just find another one, can’t you?”
Well, I’ve tried at least 6 different ones and they ALL have this problem. So I kinda wanna fix it, learn how to fix it, or get my hand on one that isn’t messed up :sweat_smile:
All of @just_randy 's parts look to be incorrect (plus is swapped with - between views.) The desirable solution is for @just_randy to correct them and replace the parts in the post with correct ones. Until that happens, here is a corrected version of the 2 cell version you were asking about and what needs to be done to correct it. This tutorial should give you everything that I am doing here, but part creation in general is quite complex (more so in this case because at least one of the parts has bendable legs which is among the most difficult to deal with!)
Breadboard looks to be correct:
here hovering over the - pin shows the pin is labeled as pin1 (connector0) and as the negative side of the battery. In schematic the svg is reversed:
here the negative pin is showing as pin2 (connector1) the positive terminal instead of pin1 (connector0) the negative terminal. That is because the pins are reversed in the schematic svg (displayed here in Inkscape)
to fix that we need to modify the schematic svg to correct the pin number like this:
where I swapped connector0 for connector1 and changed the pin labels so pin 1 is the negative and pin 2 is the positive. Save this as a plain svg, then rebuild the part and run it through FritzingCheckPart.py to clean it up and remove the px from font sizes and we have a new corrected part.
2x_18650-fixed.fzpz (11.4 KB)
note you will need to delete the current part from the mine parts bin and restart Fritzing before you will be able to load the fixed part because I didn’t change the moduleId or file names. Hope this helps!
Thanks for the solution. It is much better for lil peep.
