Help finding DF ROBOT BMP 388
Hi there! I need some help finding a DF ROBOT BMP 388. All I was able to find was an Adafruit BMP388 and it doesn’t match the one I need to use for my project…
Here is the datasheet for this component:
And here is the project by the way (if it can be helpful in some way)
CanSat-Xanthoria-Fritzing-2.0.fzz (116.3 KB)
Do you want the surface mount component or a breakout board that uses it? There is a request outstanding in another thread for a DFR breakout board for this same device but in a breakout board. It doesn’t appear that you would be able to hand solder this device as the pins are under the device and thus a breakout board would be easier unless you have an SMD reflow oven.
Peter has made the part and here it is
Thank you so much for the help!
Thank you so much for help.
