Hello! I was wondering if anyone created this part.
GC9A01 1.28-Inch Round LCD TFT Display
This part may do what you want
Did anyone have the GC9A01 (like in the picture) with 7 pin?
It doesn’t appear so. The waveshare 8pin is the only part I see. If you supply a web site with the physical dimensions of the part you want (a google search for gc9a01 brings up another 8 pin version but not the one in your picture) it is possible to make one.
For future reference you need to supply a web site like this which has physical dimensions and connector information for the part you want (pictures are by and large useless.)
https://universal-solder.ca/tft-display-round-1-28-240x240-gc9a01/
that said this part should do what you want.
edit Mar 1 2025
There is an error in the part in pcb view. One pad had a fill of #000000 rather than none which creates a pad with no hole when exported as an image to etch. Uploaded a new part that corrects that.
gc9a01-round-lcd.fzpz (5.1 KB)
Hi, Thanks. Did find something Else like it, the display with a build in esp32 witch i am thinking of using: [https://www.waveshare.com/esp32-s3-lcd-1.28.htm]
Do you know where to find that?
There likely isn’t a Fritzing part for it. One could be made but it is a fair amount of work and the connectors would need to appear in the screen in breadboard.
I am not the good at this, but could you help me?
Sure it will be up in a while.
This part should do what you want. Of note the connectors are as seen from the front (thus are swapped left to right compared to the documentation which is from the bottom of the board.) Also as they are 1.27mm connectors you likely have to start at the 1.27mm pin end to get a successful connection to a 0.1in header.
waveshare-esp32-s3-lcd.fzpz (9.3 KB)
I found this site in a Google search: Round Display - RJY Display - Customized Display Solution Supplier
Maybe they have what you’re looking for (maybe not), it’s always good to try!
