may do you. The tab connectors (which require a slot in pcb view) are a problem in Fritzing so connecting them via a wire is usually the easier method.
The square pins make such a part difficult in Fritzing. You could make a part with large circular holes, or use wires to connect to the tabs, but I don’t know of a way to make slots in a part.
