While it is out of date for the current Inkscape version, the process is described here (I will update for the latest Inkscape in a bit.) It isn’t really important, the svg will work the same at any scale, it is just what the part standard calls for and is more familiar to me.
I’m using Inkscape 1.2.2 (732a01da63, 2022-12-09) which I think is the latest version (last I looked.) The font size change is likely the transforms in the groups, they change the font sizes. I typically ungroup the entire svg as Fritzing only needs a single group with the layerId (breadboard or schematic) except for pcb which needs two or three (depending on if the part is SMD or not.) Ungrouping also removes most transforms which I find desirable. With that done the font sizes are different.
Only for through hole parts. An SMD part only has copper1 (the top layer)
It isn’t necessarily a requirement, a schematic will work (sort of) with any alignment, but it won’t match most other parts which is undesirable. The two rules I follow in schematic (as does the extension) are aligns to the 0.1in grid and is small as possible (because space in a schematic is valuable.)
Again any value will work (as long as the fzp file matches the value in the svg) it is just very annoying (and it will cause FritzingCheckPart complaints) to have the internal connector numbers not all match when you are attempting to modify a part. Some of the parts in core parts do this and eventually they will get corrected (but haven’t yet!)
remove the groups to remove the transforms (especially true in pcb, the gerber code in the past sometimes didn’t correctly process transforms and I don’t know if that has been fixed.)
I don’t thing that is all that easy, and the volume here isn’t high enough to make it all that important.
