Hello, is someone know to to get the part for PH-4502C (PH Sensor?)
Thanks!
vanepp
June 17, 2021, 5:40pm
2
This looks like it should be what you want (found with a google search for “fritzing part PH-4502C”. Note there is a corrected version near the bottom of the series of posts.
That did the job, thanks! I grabbed the bb image of a BNC connector from core parts, rescaled it a bit to match the space (the barrel isn’t long enough but close enough!) removed its connectors and pasted it in to bb giving this:
[PH_meter_bb]
which with your background makes this about as good as it gets I think. This is the latest version of this part with the above change in it.
PH_meter_1.fzpz (65.6 KB)
In this case the “board” is made up of 4 line paths (in a rectangle) and 4 arcs (th…
Thanks Vanepp, actually, I am looking for this model here:
The conections are different between them.
Thanks!
