Anyone knows where I can find the part for a nodemcu32s esp32 dev board(v1,2), by AI Thinker? It is the one with 19 pins on each side, as detailed in this document:
This one is the closest match that I see
a google search for “fritzing part node32s” will find all your choices. Note there are at least 3 different widths to these boards. You look to need the 0.9in wide version (there are also 1.0 and 1.1in versions.) and 19 pins per side.
