Many thanks Peter for the Firebeetle 2 Fritzing part! I have seen that the Firebeetle can be mounted through-hole but has castellated holes also, to mount it SMD-like on top of an other PCB, see https://dfimg.dfrobot.com/store/data/DFR0654/DFR0654-datail-002_564x376.jpg?imageView2/1/w/564/h/376
So I like to try adding pads on my fritzing PCB. First I thought it could be a good Idea to edit FireBeetle-ESP32-E-tht_1_pcb.svg and adjust the THT connectors with longer pads as described in https://forum.fritzing.org/t/generic-ics-with-oblong-rectangular-pads/6140/14 but the needed pads are longer than the board itself. So I would have to make the component for the PCB bigger than it is in nature. An other approach would be to add simply pads on the fritzing PCB view:
Does this work for production because the pads overlapping with the holes? It looks ok, at least in a Gerber viewer.
