vanepp
December 3, 2023, 3:54pm
2
You can’t edit the svg from the parts editor you need to use a svg editor such as Inkscape to change the svg. Instructions are available in this tutorial:
Someone in this forum post
requested help to fix up a part. So while doing that I decided to record what I needed to do in order to fix the part to provide a tutorial to create new / fix broken parts. If you start from the Tarjeta S4A EDU.fzpz file posted in the above thread, you should be able to recreate my improved part posted in the same thread. I started by loading the original part in to Fritzing, that indicates breadboard is (at first look anyway) pretty good, but schematic and pcb are…
