(duplicate, solved) Where can i find this two parts
I’m using somone’s Fritzing schematic as an example for my work but I can’t find this part anywhere, at least not by searching within Fritzing or on this forum.
Could someone please point me to this part, or at least a similar one I can use in my Fritzing schematics?
@satriabaja Fill up the template (which you’ve ignored)
Have you done a **Google Search** of the part
>fritzing part [part name]
>e.g. fritzing part l298n driver module
[ ] Yes, not found
[X] No/Unread (we *may* ignore this part request if ticked)
**Name of the part**
Name
**Similar work/own work**
In case there are similar Fritzing parts, or you already started work, please link/upload it here:
**[High-resolution top view, flat image]()**
This picture shows the part from above, so that is easy to see where connectors should go, and which diameter they have.
Photo or vector graphic, no links here, please.
**[Datasheet/Website]()**
Please, please **add a link** to the PDF of the manufacturer’s datasheet/the website where the part was taken from (**must** have **[connector information, name]()**, and **[part dimensions]()**)
**Footprint (optional)**
E.g. SOT23-5, TO-220.
(required fields [coloured in red 🟥]())
Please **[DO NOT]() just give images/descriptions**. If you do not fill in required fields, we might not entertain this part request
Copy this code, fill it up and post
Edit:
As well the part you are using above is BAD (quite bad – the person who created that doen’t even know how to!)
Whole thing please (don’t just give some parts of the template!)
im sorry, i dont mean that, thank you for your advice, i will ask who created that wiring
In this case the appropriate google search which is “fritzing part power supply” this is probably this post:
well the creator of wiring say that is power supply 12 v but i need 5 v same shape
Since Fritzing doesn’t care what voltage the power supply is it isn’t worth making a new part for one of a different voltage. There are an infinite number of parts, we can’t have all of them so generic parts are the rule.
thank you i will searching for the parts and datasheet
Both have the same connections (power input, voltage output) as the existing power supply which will serve. Not worth making a new part.
well how about the plug?
What plug? If you mean an AC power plug there likely are some, but nothing to connect them to (and no purpose in making any.)
you can just add an image with the breadboard image part
im sorry it dont allow it to share full breadboard, but i will share the image and datasheet
thank you very much but how about power supply?
@satriabaja Here
