Good day!
I am having a project thesis that uses the (DFRobot Dissolved Oxygen Sensor V1.0)[Gravity__Analog_Dissolved_Oxygen_Sensor_SKU_SEN0237-DFRobot] . I need this part for my schematic diagram. Please help.
Good day!
A google search of the form “fritzing part dfrobot dissolved oxygen sensor” turns up this post from 2018 which appears to be what you want.
That is for a PH Sensor by DFRobot, I am looking for a Dissolved Oxygen Sensor which is different from the link you gave.
True, but the board layout and connectors are the same for the two parts and thus the ph sensor is identical (as far as Fritzing is concerned) to the ph sensor. If you really want only the oxygen sensor I can modify the ph sensor to be one but as noted there will be no practical difference as far as Fritzing is concerned.
I see. The modified visual display only for the dissolved oxygen would be much appreciated.
Thank you so much!. While were at it, is it possible to have also the
EC Meter Sensor from the same DFRobot?
Can you please provide fritzing part for dfrobot oxygen sensor SEN0322 for ambient oxygen concentration?
can I get the dissolved oxygen sensor like this?
I need this one for my Master Education
