I have used copper / ground fill in recent projects with good experience. But now, with a design with curved traces, copper / ground fill is buggy and leaves empty white spaces that are not filled out:
I have filed an issue on https://github.com/fritzing/fritzing-app/issues/3932 but searching for a workaround because development is not much active at the moment. What can I do to reduce or eliminate this wrong behavior and get smooth and complete filled out grounds / copper plates?
What Fritzing version are you using? Development is in fact occurring and there are fixes in Fritzing 0.9.9 (I don’t know if this particular thing is fixed though!)
Fritzing version 0.9.9 is here running on a Windows machine. I know only https://fritzing.org/download/ as download source. Is there a nightly build or beta version with newer code available? Or is this the latest and gratest?
While reading todays “digest” e-mail aka “[fritzing forum] Summary” I noticed this thread about a faulty Gerber export and some workaround with export and import magic to fix the problem:
Seems that there is no solution for my described problem above, but do anybody have an idea how to fix the curved traces issue with editing the relevant file directly?
Or would it help to add additional elements (what, where?) to force Fritzing to fill the empty gaps?
