Connect muliple leds to power
Hello there,
Best wishes to 2025.
I’am trying to connect wires from power jack to 12 leds.
6 connections i have made now buth the other ones is a problem.
I checked this one: Have problem making two wires connect to each other - #3 by vanepp
See my fzz file.
15. Snoertjes.fzz (52.2 KB)
Who can help me?
Thanks.
Bert from the Netherlands.
When the going gets tough the touch cheat! Your problem is a combination of bendable leg parts (the LEDs) that I dislike and many connections to a single point. The usual way of doing this would be to start at the LED connection and extend the wire to the power supply (which incidentally doesn’t have a ground connection and thus won’t work!) but with bendable leg parts that won’t work. So use a 2 pin (because it is the default, a 1 pin header would work as well) then connect the wire to the LED from the header. Here I started at the header and connected to the LEDS.
then move the wire from the header (which is not bendable leg) to the power supply like this
then do the other one
then left click on the power supply connector to make sure all the connections got made correctly
the left click on any connection point lights all connections in that net yellow, so check all the LEDs are properly connected and you should be away (you need to change the wire colors which I didn’t do) and problems solved.
Hi Peter,
I succeeded with the pin header.
Thanks a lot.
Bert
