Can't find a part in library
I need this part:
OLED-128x64-I2C-Monochrome-Display-GND-VDD
I know it should be in a bin but I can’t find it…
I hope this is what you are looking for.
OLED 128x64 I2C Monochrome Display.fzpz (15.4 KB)
Regards,
Nandan
One of the two parts here should do what you want. These things come in two versions with the power pins swapped so make very sure you have the correct version before using it, as using the wrong part will likely destroy the LCD!
