Hello everyone, I joined this group today because I received a project to work on in Fritzing. I recently heard about this software, and I have already created the schematic, which I have attached below. However, I need to implement it in Fritzing, and I have no idea how to do it. I figured out how to find the components I need, but the problem lies in making the connections between the parts. I have two Li-Po2 batteries connected in series to power the system, four 6V geared micro-motors, and the component labeled Ax3484 is a mini360 converter. If anyone here has the necessary time to help me, I would be grateful. I need to submit the project tomorrow evening. Thank you in advance for any responses.
Your DRV8833 part is broken. There is a corrected version available here:
so you need to replace that part. There are no connections from the batteries to anywhere (looking in schematic) they connect to each other but nowhere else.
