Whatever way makes the routing easiest and satisfies the drc requirements (and the fab house’s requirements) is good. Between the pins usually has the least space and takes the most care to route (i.e. you likely need to reduce the grid size to get enough clearance) but as long as the spacing is enough for your fab house that’s fine.
