BH1750 light itensity sensor part submit
Hello everyone here is the BH1750 part (light intensity sensor) library you can download it from
Nandan
A few issues schematic lacks teminalIds and thus connects in the center of the pin rather than the end. The part lacks a label field in the fzp file and thus uses “part” (it should be set to ‘A’ for assembly.) In pcb the hole sizes are a bit too large (0.04in rather than the standard 0.038in for headers.)
As well FritzingCheckPart.py finds a couple of errors (the lack of a layerId in schematic will cause the part to not export as an image.)
Error 69: File
‘svg.schematic.BH1750_27ff8a3c90bc7808d0b01da93474414b_13_schematic.svg.bak’
At line 12
Error 18: File
‘part.BH1750_27ff8a3c90bc7808d0b01da93474414b_13.fzp.bak’
Connector connector8terminal is in the fzp file but not the svg file. (typo?)
svg svg.schematic.BH1750_27ff8a3c90bc7808d0b01da93474414b_13_schematic.svg.bak
This tutorial should assist you in fixing these
OHH ok thanks ill try to fix it
